Twitter slowmo basic question. Final Cut Pro
COW Forums : RE:Vision Effects
peter Davison
on Oct 16, 2010 at 2:41:39 am
I've been trying to get twixtor working for hours. I'm using final cut pro.
I either get a black screen, no change, or a freeze frame of image upon rendering.
here are the steps i've been taking:
1. import clip
2. copy it a few times
3.make a new sequence
4. drag old sequence into the new one
5. find the twixtor filter and drag it onto the clip
6. change the speed between 100 to 50, 0 or -50.
7. render.
8. cry.
Any ideas?
Pierre Jasmin
Re: Twitter slowmo basic question. Final Cut Pro
on Oct 16, 2010 at 11:02:53 pm
Need more info
1) Are you running FCP 6.0.3 or over?
2) Did you download the right installer?
http://revisionfx.com/products/twixtor/downloads/#fcp
Pierre
RE:Vision Effects
peter Davison
on Oct 16, 2010 at 11:49:40 pm
Hi, thanks for the reply.
I'm using FCP 7 and I did use the right installer.
I've actually semi got it working now...I'm not really sure what I'm doing differently. I think it has to do with the time I'm copying the clip. Maybe I wasn't making it long enough?
I'm actually trying to slow down some hockey slap shots. I'm getting a lot of blurring on the stick...everything else is fine. I've only shot it at 60 fps. Is it unrealistic to expect better results than that? I'm just experimenting with speed percentages at the moment
Pierre Jasmin
on Oct 17, 2010 at 5:38:16 am
Peter,
In case, you might like these tutorials to understand the sequence length workaround for FCP
You can go here:
http://library.creativecow.net/search.php?q=Twixtor
1) Twixtor Overview for FCP
and
2) Twixtor Speed Ramp in FCP
For the blurry sticks they probably move too fast to be tracked, you might need some creative solution like doing it two times with different settings and using a very soft matte to composite one render over the other. You can send me a few frames to techsupport at revisionfx dot com and I will look at it. It's much easier to fix that if the camera is locked (on a tripod) or pre-stablized...
Pierre
RE:Vision Effects
