The secret: Re:Flex create virtual cameras for Stereoscopic 3D
COW Forums : RE:Vision Effects
clyde desouza
on Aug 31, 2010 at 12:20:02 pm
I had been using the Re:flex plugin to "generate" in-between "virtual" cameras a few years ago, when auto-stereoscopic 3D displays (from Philips, Newsight etc) were all the rage.
Well, now that Hollywood has re-discovered 3D, one of the biggest debates you will hear is about how cumbersome it is to shoot with a beamsplitter rig, and how if you just place to cameras side by side the interaxial (the distance between the lenses) is too large.
Now Re:Flex solves that problem to a very large extent with great results.
In the spirit of sharing knowledge, I've documented it as the RealFlex 3D camera rig method here:
http://realvision.ae/blog/2010/08/3d-camera-interaxial-and-convergence-usin...
Hope it's of help to the community.
Regards
Clyde
"Think in 3D"
Clyde DeSouza
http://www.realvision.ae/blog
Pierre Jasmin
Re: The secret: Re:Flex create virtual cameras for Stereoscopic 3D
on Sep 1, 2010 at 8:53:02 pm
Thanks Clyde, looks good.
Pierre
clyde desouza
on Sep 3, 2010 at 9:56:04 am
Hi Pierre,
I was wondering if there is a chance of having this plugin work directly in Premiere Pro CS5. I understand that it needs a "mask" that is obviously only an AE thing.
But for this specific use of the Motion Morph plugin, it works in AE even without a mask.
There is huge potential for usage of this technique for the Stereoscopic 3D community.
I will be adding it in a "recommended" section of the Real Vision knowledgebase as a must have tool for 3D shooting.
An animated Gif showing the effect is here: http://realvision.ae/blog/wp-content/uploads/2010/08/Clyde_realflex_3D_rig.gif
Would be great to discuss with you further,
Best Regards
Clyde
"Think in 3D"
Clyde DeSouza
