23.98p to 59.94i using Twixtor and FCP?
COW Forums : RE:Vision Effects
Ron James
on Aug 24, 2010 at 8:40:49 pm
I've searched all over the place and watched the Twixtor frame rate conversion tutorial (on both the RE:Vision site and on the Cow) but I'm still unsure if it's possible to do this conversion using Twixtor and FCP: 1080 23.98p to 1080 59.94i.
I thought I'd be able to use the same method outlined in the tutorial, but there's a note on the RE:Vision site which reads "Frame Rate Conversion when converting between interlaced 29.97 or 25 fps material to 23.98, 24 or 59.94 progressive material: Because FCP doesn't recognize interlaced clips that aren't 25 or 29.97fps, our method of conforming the frame rate within Cinema Tools does not work within FCP."
I'm not sure exactly what this means? Is there any method for using Twixtor to convert 23.98p to 59.94i? My goal is to create a 59.94i master that has clean cuts.
Lori Freitag
Re: 23.98p to 59.94i using Twixtor and FCP?
on Aug 25, 2010 at 5:16:46 pm
First of all, you need to conform to 29.97. Drop that into a sequence following the Frame rate conversion tutorial (using 23.976 , NOT 23.98! As the source frame rate), and 29.97 as the output frame rate. That means you will apply Twixtor with a speed change of 80% (which is 23.976/29.97).
The key here: make sure the sequence you drop Twixtor on is set to have lower or upper fields first as part of the sequence settings. This will tell Twixtor to create interlaced frames!
The other tutorial you should watch (to get clean cuts)is the one on Marking Edit points in Twixtor within FCP (since your edit has cuts) http://library.creativecow.net/articles/freitag_lori/twixtor-fcp-edit-point.....
Ron James
on Aug 26, 2010 at 1:10:32 am
Lori...
THANK-YOU!
Sorry for the all-caps, but I'm very appreciative. I'm going to watch the tutorial and try this. I'll report back after my next QC.
Thanks again,
Ron
