Visual effect required...
COW Forums : RE:Vision Effects
Michael Palmer
on Aug 12, 2010 at 4:31:25 pm
Hi Guys,
I have a client who wants to get an effect they have seen on a YouTube clip... It is kind of a washed out grainy look that they like.... The colors are more vibrant but skin tone is washed out...
I have been going through my FCP effects to try to get a similar effect but haven't been able to get close yet...
Can anyone help me out with any suggestions?
Thanks in advance
Mike P
Pierre Jasmin
Re: Visual effect required...
on Aug 12, 2010 at 9:13:47 pm
All I can think of is to use SmoothKit Diffuse a bit and some color correction (probably a few selective passes)
Pierre
Lori Freitag
on Aug 25, 2010 at 5:32:02 pm
Just to add to what Pierre said about Smoothkit diffuse, and some selective color correction. You can start with the color correction and de-saturate overall, then pull a luminance matte of selective areas (that you want more vibrant) and pump up the saturation for these areas, then you can add the Smoothkit diffuse plug-in and do an overall slight diffuse and then add some grain on top of everything. That receipe should give you a similar look.
