30fps footage, twixtor, after effects, and time.
COW Forums : RE:Vision Effects
Kalulu Ngilo
on May 3, 2010 at 8:44:32 pm
Hello everyone,
I have a strange dilemma if you may call it. I shot a series of clips at 30fps, 1/160, ISO at 400-640. Now I know or came to realize at exactly 4am that I forgot to speed up the shutter for slow motion.
Here is where it gets weird, all those clips combined have a running time of 5mins:28:20. The clips were combined to a single neoscene avi file. I throw the clip in After Effects, I twix'd, by the end I have about 14x2 key-frames, reason why I say X2 is because there are 14 sets. A start point(20% speed) and finish(100%), 14 times, so altogether its 28 key-frames.
I hope I haven't lost anyone yet.
I open premiere, I line up all clips and at 4:52:22 the shot is different to when I compare it to after effects' time. If I disable the plugin by clicking the FX toggle then the shots match up(look the same).
I realize this has to do with me slowing down the footage too much... something to do with frame interpolation. I have my Frame Interp. @ Blend.
I'm I stretching this too far? How can I fix this that when I slow a point of the clip down it just extends the frames(clip) past 5:28:20? Is the trick or magic to slow motion in the shutter only? I got this to work before with a shorter 19sec clip so I have no idea what I 5min would react to all the key-framing.
I know in premiere when you slow down a clip it gets longer in the timeline but this is a single clip in after effects using twixtor. Anyone have any ideas? Please do let me know if I didn't get my point through.
Thanks.
Pierre Jasmin
Re: 30fps footage, twixtor, after effects, and time.
on May 4, 2010 at 1:38:56 am
Before you panick
In AE set the project preference to display in Frames
In Premiere, over the timeline on the left (where it displays timecode) - set the time display to Frames
Now at Frame N in each, are you on the same frame?
Pierre
Kalulu Ngilo
on May 4, 2010 at 1:47:41 am
its not that I am having issues with matching frams its because techically my clip is 5:28 but towards the end there are credits. If the FX are active I never get even close to the credits. Its like the clip is at 4mins and change. It's stuck in time? :/
Kalulu Ngilo
on May 4, 2010 at 5:44:46 am
and I did set Project Settings as you instructed and still no effect.
Pierre Jasmin
on May 5, 2010 at 1:28:40 am
You mean the sequence is too short?
http://revisionfx.com/support/faqs/generalfaqs/sequences_longer/#After%20Ef...
Pierre Jasmin
on May 5, 2010 at 2:30:44 am
Or http://library.creativecow.net/articles/freitag_lori/twixtor-overview/video...
second part from 5 minutes
Same tutorial exists on Lori's page for Premiere
Kalulu Ngilo
on May 5, 2010 at 2:38:58 am
thanks for the post in the support FAQ, it seems to work. Yes my sequence/timeline was shorted by slowing down the video.
