RSMB and text issues cs4 intel mac
COW Forums : RE:Vision Effects
Emily Scollon
on Mar 15, 2010 at 4:25:51 pm
i saw a previous thread that mentioned using smoothkit for per character text animation. I followed the rsmb invert green layer effect per this post as well: http://forums.creativecow.net/thread/69/854785#854788
My issue is that it only happens on a fluke couple frames, where the text blur just goes haywire. Is my only solution to purchase this other plugin? are there not any other work arounds?
thanks for your help~ emily
Peter Litwinowicz
Re: RSMB and text issues cs4 intel mac
on Mar 15, 2010 at 4:43:25 pm
We have a limitation with RSMB that each frame needs to be the same size, and when text animates in After Effects we are reported differing sizes from frame to frame.
The solution is to precompose your text layer, and then apply RSMB to the precomp (within another comp, of course).
Cheers,
Pete Litwinowicz
RE:Vision Effects, Inc.
Emily Scollon
on Mar 15, 2010 at 4:49:18 pm
hmm i did put the effect on the precomposed animation...
Pierre Jasmin
on Mar 15, 2010 at 5:24:40 pm
Any way you can send us a project that replicates the problem?
to techsupport at revisionfx dot com
Pierre
Emily Scollon
on Mar 15, 2010 at 5:37:07 pm
sure can, i'll send it over tonight when i have access to the file! the AE file correct?
