RE:Visions Fields Kit and eyeon Fusion 5.2/5.3
COW Forums : RE:Vision Effects
Mark Dauth
on Jan 13, 2010 at 9:58:42 am
I am trying to run RE:Visons FieldsKit in Eyeon Fusion 5.2 and 5.3 32bit.
The Aex files are Read corectly and the Plugin is avalible in the AE Plugin list but when i connect a loader with fieldet footage (set to fullframes) to it the immage turnes bright magenta and i do not see the result of the defield. the settings sliders are all avalible.
i am running a 32bit version of Fusion on a Vista x64 System.
everything else is pretty standard.
RE:Visions Real Smart Mation Blur works fine.
does anybody have any ideas?
Ciao Mark
Pierre Jasmin
Re: RE:Visions Fields Kit and eyeon Fusion 5.2/5.3
on Jan 13, 2010 at 4:46:40 pm
You have to connect the second input of node for it to work.
We had to do that historically as some cases otherwise did not work properly in Fusion.
Pierre
