45º Shutter/Saving Private Ryan effect
COW Forums : RE:Vision Effects
Kenn Bell
on Dec 6, 2009 at 7:05:22 pm
Can I use ReelSmart Motion Blur to get rid of motion blur and create a 45º Shutter/Saving Private Ryan effect?
Pierre Jasmin
Re: 45º Shutter/Saving Private Ryan effect
on Dec 6, 2009 at 7:31:26 pm
get rid of motion blur: use Amount under 0
that only works for small reduction typical of say going from 24 to 30P... not for long streaks
private ryan like: you can set Amount to larger then 1 but you might get better results from there by applying after something like SmoothKit Frame Accumulate to control the frames window and leave RSMB at 1. To simulate exactly the process where the effective frame rate of the camera is reduced by having shutter open for longer then a full frame interval you can then posterise time (in AE for example that would be creating another comp for that)
Pierre
RE:Vision Effects
