Beginner-friendly tutorial for Twixtor Pro?
COW Forums : RE:Vision Effects
Juuso Voutilainen
on Oct 30, 2009 at 8:50:44 am
Hi, I have read the Twixtor and Twixtor Pro manual and searched the internet and Creative Cow forums quite a bit thoroughly without really finding a informative tutorial about creating and applying the foreground and background mattes, usage of tracking points and geometrical splines, all of the advanced motion guidance tools. So I would like to ask that if there exists, or if anyone could take some time and explain how to use this advanced features I would be very, very grateful. I am searching for best-possible slow-motion, and I am not getting satisfactory result with default settings, alot of disturbing artifacts appear. I have tried RealViz ReTimer PRO also, it has quite a bit good results, but it has some glooping (background distorting near foreground objects) and the output slow-motion video suffers from somekind of flickering (rapid luminance changes in video), so that is not good either. I am using Canon HV30 with 60i mode and a shutter speed of 2000. Thank you very much
Greetings
Juuso Voutilainen
Pierre Jasmin
Re: Beginner-friendly tutorial for Twixtor Pro?
on Oct 30, 2009 at 7:06:30 pm
Not sure in what application you are tyring to run this in. For PRO features right now all we have is sample projects
http://revisionfx.com/products/twixtor/help/#after_effects
(at the end of that section)
and some explanation in the html doc that comes with the installer
Feel free to contact http://revisionfx.com/support/contact/
It will autorespond with an ftp site login for you to send sample example for you to get additional help from support
Pierre
Juuso Voutilainen
on Nov 2, 2009 at 12:59:21 pm
Oh, I'm using After Effects CS4
Juuso Voutilainen
on Nov 18, 2009 at 6:49:31 pm
Pierre, does Twixtor need foreground and background mattes for best slow-motion results? And if it is so, does it need frame-by-frame rotoscoping?
Eugene Lehnert
on Mar 17, 2010 at 3:29:26 am
I am having a similar problem. I read the manual but I still get many artifacts. Did anyone post any advanced videos online somewhere?
Pierre Jasmin
on Mar 17, 2010 at 3:36:19 am
You mean like this?
http://library.creativecow.net/tutorials/revisionfx
The ones at the bottom are for AE
Eugene Lehnert
on Mar 17, 2010 at 2:46:26 pm
Thanks. I've seen these though. I'm looking for tutorials that feature the matte, tracking and spline options of Twixtor. My expectations might be high for the footage but I want to know the extent to which Twixtor can handle strange warping artifacts.
Pierre Jasmin
on Mar 17, 2010 at 5:49:07 pm
We currently only have the sample projects here
with the short explanation in the file:
TwixtorAEExamplesReadme.htm
