Converting Canon 5D Mark II 30fps to PAL 25fps?
COW Forums : RE:Vision Effects
Mika Huhtanen
on Apr 7, 2009 at 7:17:33 pm
Any experiences with this kind of conversion? I'm purchasing a 5D, but this conversion dilemma might just change that.
+Mike
Pierre Jasmin
Re: Converting Canon 5D Mark II 30fps to PAL 25fps?
on Apr 7, 2009 at 8:06:22 pm
Some of our clients do use that camera, but I forget the issues this second.
Questions/Notes would be:
1) Within what software?
2) If AE, the thread jan 6 - Tidier workflow might be helpful
3) There is two issues, the frame rate issue and if or not there needs to be resizing (SD NTSC and PAL is not the same image format)
4) If you ever plan to use fields, would advise also to get some test footage before buying, upload it and we can look at what it looks like after the image is loaded.
Pierre
Mika Huhtanen
on Apr 7, 2009 at 8:27:09 pm
I'm using Newtek SpeedEdit. Plan is to publish on DVD & BD. There might be some footages flying in the net somewhere. I'll try to get my hands on original material with some movement on the picture. I'll keep you posted!
+Thanks
Pierre Jasmin
on Apr 8, 2009 at 12:29:10 am
I see, we might not be able to help too much thought as we don't have plugins that run in SpeedEdit.
Pierre
