UV Resolution stinks
COW Forums : RE:Vision Effects
Evan Weiss
on Jan 15, 2009 at 7:44:40 pm
Im having trouble getting quality resolution using the UV texture mapping effect in After Effects. Instead of looking like clean 16 bit images, it comes out looking like an 8-bit Nintendo game. I noticed that the tutorial Revision FX supplies, which looks good, is in an extremely low resolution. Is it possible to use this effect well in high res?
Pierre Jasmin
Re: UV Resolution stinks
on Jan 15, 2009 at 9:57:33 pm
Usually when someone has this problem it's because either:
1) The UV map was not rendered at at least 16 bpc
or
2) Their AE project is at 8 bpc
If not that, send a UV map to techsupport at revisionfx.com
Misha Mazor
on Mar 19, 2011 at 12:21:13 am
Thanks for the solution! Let me write out the problem again, so that someone may be able to find this easier in a search:
If you are getting pixelated, low resolution textures using RE:Map or YY_UVmapper in After Effects, make sure to render your UV map in 16bit and set your AE project higher than 8bit.
Misha
