tidier workflow
COW Forums : RE:Vision Effects
Chris Wright
tidier workflow
on Jan 6, 2009 at 10:02:03 am
I've been trying to figure out a better, faster, less mind-numbing way to fix hard edit points after they are rendered out from premiere. When I use twixtor in AE, I sometime have to create keyframes from "twixtor output" to "source" to erase gloops, but finding them by hand is very tedious if you have hundreds of cuts.
I finally discovered a free plugin that will create markers so that you can simply hold shift, drag to the marker and ctrl+v the twixtor keyframes.
http://aescripts.com/magnum-the-edit-detector/
I'd love to hear any other ideas out there.
Pierre Jasmin
Re: tidier workflow
on Jan 6, 2009 at 7:03:51 pm
One easy solution for you would be to not render the movie in Premiere and simply save the project once your edits are done and import in AE. (The File | Import | Premiere Project).
Pierre
Chris Wright
Re: tidier workflow
on Jan 6, 2009 at 9:10:27 pm
Thank you for your reply.
Would this method work with changing framerates to a slower framerate for an imported comp?...because I use a solid to access the longer footage.
Pierre Jasmin
Re: tidier workflow
on Jan 6, 2009 at 9:17:05 pm
For frame rate conversion
1) Import the Premiere Project which creates a comp with sliced layers stacked
2) Reset Comp (comp settings to wanted FPS)
3) Apply Twixtor to top layer (set Input FPS to original FPS)
4) Copy Twixtor
5) Select all layers (then unselect the top one where Twixtor is already there)
6) Paste Twixtor - you now have Twixtor on each layer and FPS conversion for the whole sequence
-- and in AE the audio still matches
Pierre
Chris Wright
Re: tidier workflow
on Jan 29, 2009 at 8:25:11 am
I tested this method but the color source does not dynamically update. You still have to go to each twixtor layer that you pasted and change its color source of video1 to its corresponding
layer. example 75. video1.avi
I noticed that twixtor, when dragged onto a layer from effects controls, it automatically assigns the correct color source. Perhaps I am missing something in the batch process of pasting.
To workaround, I have decided it is easier to twixtor all the pre-edited video into large groups. This fixes 3 things.
1. Twixtor glooping from hard cuts. I now can just use excess video handles and edit them off.
2. Dynamic link doesn't support titles anyway.
3. Special Effects don't need rotoscoping anymore.
Pierre Jasmin
Re: tidier workflow
on Jan 29, 2009 at 1:43:57 pm
You are correct, I had not testing that trick for a while
that technique used to work
Presets for layers are busted too in the same manner
Pierre
// I will report it's not working anymore to AE team
Pierre Jasmin
Re: tidier workflow
on Jan 29, 2009 at 2:18:11 pm
I found a workaround
After you applied Twixtor all layers
Select all layers (CTRL A)
Copy
Create a new comp
Paste
- Now it points to the correct layer
Pierre
Pierre Jasmin
Re: tidier workflow
on Jan 29, 2009 at 3:40:06 pm
This also seems to work
Duplicate Comp1 in Project bin
Go to Comp2
Apply Twixtor to Layer 1, set FPS value
Cut
Go back to original Comp1
Select All Layers
Paste
Delete Comp2
Chris Wright
Re: tidier workflow
on Jan 29, 2009 at 5:52:01 pm
hats off to you.
Thanks a lot!!!
