ReelSmart Motion Blur and Nuke on Command Line
COW Forums : RE:Vision Effects
Alex Soliven
on Dec 15, 2008 at 4:01:14 pm
I'm running the latest version of ReelSmart Motion Blur on Nuke5.1v2 32bit and winXP 32bit.
I've developed a script that tells nuke to render all active write nodes in a nk file. Here it is:
Nuke5.1.exe -xi -m 2 -V
My script scans all nk files in a directory and renders everything. The problem is, when ReelSmart Motion Blur nodes are enabled, it just hangs during loading. In effect, it doesn't render anything at all.
It does work if you disable the ReelSmart Motion Blur nodes.
Pierre Jasmin
Re: ReelSmart Motion Blur and Nuke on Command Line
on Dec 16, 2008 at 6:22:17 am
As I explained in email, but for the sake of others, this is typically a sign that you are running an older version of the license server with a newer version of RSMB.
I am sure you will be back if this does not solve your problem.
Pierre
