COW Forums : RE:Vision Effects
Juan Zelaya
on Oct 21, 2008 at 8:52:29 am
Is there a Video Tutorial about making slow motion with twixtor? Its kind of complicated. Thanks
Pierre Jasmin
Re: Twixtor
on Oct 21, 2008 at 2:36:27 pm
Aside the doc that comes with the installer, what we have is here:
For example if you use AE or FCP press the blue bar for more
The main initial complication is to allow an application to make a layer longer then the original layer which by itself the plugin cannot do, the plugin can only fill the frames if you like. So you have to revert to nesting, pre-comp (whatever your application calls it) before you do anything.
© 2018 All Rights Reserved
