Twixtor and HDV
COW Forums : RE:Vision Effects
Rob de Jong
Twixtor and HDV
on Sep 2, 2008 at 6:07:01 am
Hello,
Can Twixtor deal with HDV material. How are the results in comparison with SD.
What are the system requirements for Twixtor dealing with HD?
Rob
Pierre Jasmin
Re: Twixtor and HDV
on Sep 3, 2008 at 9:49:46 pm
There is not much particular I can think of to HDV other then it will take more time to process then SD (more pixels) and it can be pretty noisy (eg a small pass of DE:Noise prior could help if you plan to as well play with colors. If your HDV is green screen you probably want to key out prior to retiming though.
Pierre
