Re:Fill Noob
COW Forums : RE:Vision Effects
Ivan Garcia
Re:Fill Noob
on Jul 11, 2008 at 2:41:30 pm
Hi, i'm trying to use Re:Fill in AE to remove a vertical scratch. I've read the manual, but I don't get it, I don't know how to use the plug-in, anyone can help?
Thanx in advance
Ivan
Pierre Jasmin
Re: Re:Fill Noob
on Jul 11, 2008 at 6:56:36 pm
You need to provide a matte of where the problem area is (if you burn the hole in alpha channel, zero alpha is hole)
eg:
1) draw a mask 4 points rectangle that covers the bad area
2) set Mask to Subtract
3) set (HOLES)-White ON (check box)
4) set process mode to Filled
5) set Method to Blended
Pierre
Ivan Garcia
Re: Re:Fill Noob
on Jul 14, 2008 at 2:33:46 pm
Thank you very much Pierre.
The effect i get is very blurry, any tip or trick?
Ivan
Pierre Jasmin
Re: Re:Fill Noob
on Jul 14, 2008 at 6:28:55 pm
It's meant for small holes
If there is camera movement or rig movement sometimes you want the Process Mode to be Filled Hole Only and you add some color noise a bit and composite back over original.
If you have 5 frames with the matte you can send to techsupport@revisionfx.com for visual inspection as I possibly imagine something else then what you have as a problem.
Pierre
