NTSC to PAL resizing - Twixtor + Fieldskit
COW Forums : RE:Vision Effects
Anmol Mishra
on Apr 26, 2008 at 10:55:06 am
I read through the Re:vision Fx tutorial about NTSC to PAL conversion..Just one thing that was glossed over - it says
"Apply any additional resizing/cropping as desired."
What is the best way to resize from 480P to 576P ? I doubt the AE internal techniques are sophisticated..Do I need to buy Instant HD or search for Algosuite, or DA Resizer ??
Is there a specific method for resizing SD from NTSC to PAL that works better than others ? This would be applied to Progressive footage of course..
Pierre Jasmin
Re: NTSC to PAL resizing - Twixtor + Fieldskit
on Apr 27, 2008 at 10:34:54 pm
Well in a nutshell I think you should resize individual fields:
deinterlace -> resize -> retime
or
deinterlace -> retime -> resize
Check this: http://revisionfx.com/support/faqs/generalfaqs/NTSC_to_PAL/
and also:
Also see: http://forums.creativecow.net/readpost/69/855271
Pierre
Anmol Mishra
on Apr 28, 2008 at 2:14:00 am
Hi Pierre! Would you consider a request for a tutorial that combines 60i to 24P conversion and also includes the denoise and deartifactor options ?
I think your filters do all this - but its not really clear how its done..
That would be really useful..I am leaning towards MB Suite 2007 mainly because of their tutorials - but Twixtor users swear that its better 24P than MBE.
Obviously you will have a bias :-) but do you think the gap with MB Suite 2007 has reduced ? i.e. Does MB Suite uses a different deinterlacing algorithm now..?
Cheers!
Pierre Jasmin
on Apr 28, 2008 at 2:30:42 am
It's something we are considering yes...
Pierre
