Morphing on Shake with ReFlex
COW Forums : RE:Vision Effects
Nuno Pires
on Mar 20, 2008 at 12:10:47 pm
Hello,
I am trying to make a morphing between two stills with the plugin Reflex Morph on Shake, but I can't understand how to use reflex tools to mark points and shapes in each image (the "from image" and "to image"). Is there a tutorial explaining how to do it?
Actually, I don't mean to make a real morphing, but transform a white face to another one. Is there a better software to do it?
Thank you.
Pierre Jasmin
Re: Morphing on Shake with ReFlex
on Mar 20, 2008 at 7:46:28 pm
Before I say more did you see the html doc that was part o install package?
Also some sample project in the support section
http://www.revisionfx.com/products/reflex/support/index.html#Shake%20(Apple...
Note if it's not obvious the second shape uses Shake rotospline offset button
Pierre
Pierre Jasmin
on Mar 20, 2008 at 8:30:27 pm
It's actually called the "Edge" button (in the viewer notice when in RE:Flex how the rotosplines control show up). Sorry each app call this something else.
If you move a rotospline and check Show/Hide and switch between From and To Sources in RE:Flex, you will see the from and to shape thing
Once you have a few matching lines, you can then maybe use the AutoAlign button (depends on how far off the source and destination are, it's usually to match two faces, or a face with a textures/shaded CG face...)
Pierre
