ReelSmart Motion Blur question (shake)
COW Forums : RE:Vision Effects
Alan Williams
on Dec 31, 2007 at 2:23:37 pm
Hello, i just got this plugin and I'm wondering if I'm missing something.
I want to composite an effect then add motion blur to the effect referencing the movement from the background plate. Is there a way of doing this?
Also can you do this with different sized footage (say via the fit node)??
Thank you!
By the way- The blur from this plugin is gorgeous! I never thought i would say that but it is!!!
Pierre Jasmin
Re: ReelSmart Motion Blur question (shake)
on Dec 31, 2007 at 10:53:45 pm
Unfortunately as you might not know Shake can only do multiple frames access on a fileIn node (I guess one of the N reasons why it went into rewrite)
The only 2 solutions I can think of are
1) render out and re fileIn
2) use Twixtor to export the MV and use RSMB Vectors using the composite as the color source input
Pierre
Alan Williams
on Jan 1, 2008 at 5:45:26 pm
Happy New Year!
I did not know that, thank you for the great response!!! :)
Speaking of Twixtor i have that "you don't know me" song stuck in my head :D
