Fieldskit 2.0 Render - Problem with Premiere Pro 2.0
COW Forums : RE:Vision Effects
Alexander Schwingel
on Dec 21, 2007 at 6:43:03 pm
I am using the Fieldskit 2.0 Deinterlacer with Premiere Pro 2.0.
If I render the timeline or export a movie the plugin reports a failure and the render progress is canceled.
Are there any special settings for Fieldskit on PP2.0? I am using the standard settings.
Pierre Jasmin
Re: Fieldskit 2.0 Render - Problem with Premiere Pro 2.0
on Dec 21, 2007 at 7:49:27 pm
Can you send us a 10 frames project with a source movie in the codec you use at techsupport@revisionfx.com and we will look at it...
Do you notice if this happens at the last frame?
Pierre
