Using REFlex motion morph
COW Forums : RE:Vision Effects
2021productions
on Oct 18, 2007 at 1:56:13 am
Hey,
i'm new to using this plug in, and i'm trying to figure it out. I'm editing a music video right now, and i want to have the guitar player start a spin with his electric guitar, and end the spin with his acoustic. i was hoping to use REFlex for this, but i'm having a hard time figuring out motion morph. I understand morph and flex and can use both of these, but the manual for reflex isn't the greatest when explaining motion morph. if anyone could help me get started i'd really appreciate it.
Aaron
Peter Litwinowicz
Re: Using REFlex motion morph
on Oct 19, 2007 at 3:58:05 pm
If you understand the Warp plugin, then the Motion Morph plugin should be easy :-).
You just need a pair of splines (AE's masks or combustion's rotosplines), just like with the Warp plugin: one of each pair aligned with the "from" movie at each frame and the other of each pair aligned with the "to" movie. And you create as many spline-pairs as you need to align the images at each frame.
Since you know how to use Warp, then perhaps you should take a look at our RE:Flex sample projects, located here: http://www.revisionfx.com/products/reflex/support/#After%20Effects (for After Effects) or here: http://www.revisionfx.com/products/reflex/support/#Autodesk%20Combustion (for combustion).
There is a project of Motion Morph examples. This is not a tutorial per se, but a project that demonstrates what a proper set up looks like. Make sure to quickly read the ReadMe file that is in the directory.
Let us know if we can answer any other questions,
Pete Litwinowcz
PJ Pesce
on Dec 5, 2007 at 7:13:46 pm
I have literally spent the last two days trying to make this plug-in work. I can't believe that for the money charged, there isn't a decent manual and a detailed tutorial for this. From reading the other posts, I don't think I'm alone in this frustration.
Cappa
Pierre Jasmin
on Dec 5, 2007 at 10:11:53 pm
I am willing to help you out step by step, but it would be useful to know in which application you run RE:Flex as the workflow varies a lot between each app we support
Pierre
PJ Pesce
on Dec 7, 2007 at 3:30:46 am
That's very kind of you.
I'm on After Effects, Mac.
Can I e-mail you directly?
Pierre Jasmin
on Dec 7, 2007 at 5:03:34 am
I would suggest you start with the Warp plugin first to familiarize yourself
1) Load a still (let's start easy) in AE
2) Drop that into a comp, put yourself at the first frame
3) Apply RE:Flex Warp
4) select the Pen tool
5) draw a shape
6) press on the effects control window (there are other ways to end a shape)
7) twirl open the layer in the timeline
8) select mask 1
9) CTRL - D on windows (Edit | Duplicate) -- now you have two times the same shape
10) make another shape (mask3), duplicate mask 4
ok now you have 4 shapes
11) twirl open mask 2 and 4 and press the hour glass button beside Mask path, now that shape is animatable
12)ok now go to the last frame
13) in re:flex check AutoHide Mask (the second parameter)
(make sure you set back the cursor to arrow - selection tool)
and the first param (a menu, says Warped Image)
14) move the visible shapes around - change the Display menu from Warped to Unwarped back to Warped -- ok you see the shapes appear and disappear accordingly. If you look in the timeline you should see the shape locks alternate as well.
15) press on the timeline play, now you have an animated warp
SO: A warp takes a "from" shape and a "to" shape and warps the image from the "from" shape to the "to" shape. The Warp Amount parameter actually controls the displacement from the original to the destination. It defaults to 100% so you get the full warp effect. Basically the Mask 1,3,5,7 are the "FROM" shapes and 2,4,6,8,... are the "TO" shapes and Mask1 and 2 go together, 3 and 4 are also a from and to pair and so on.
Yes?
OK, now the motion morph also works with the concept of a pair of shapes, except the FROM is attached to the main input (the current layer on which you apply the effect) and the TO is attached to the layer you selected in the layer param.
So turn off RE:Flex Warp and apply Motion Morph (keep the shape for now). Select another layer that is the same size for "Warp to Layer". Change Display to "Unwarped From" and turn "AutoHide" shapes on. Looks familiar? Select "Warped From" ...
Now select Warped and Blended and set both Warp and Blend slider to 50% - yes? ok it's probably not much right now, usually you set shapes for Motion Morph on the two sequences that are related, for example you trace the eye of the guy in layer with mask1 and the other guy eye (in other layer) with mask2,...
Hopefully now, if you look at the sample projects on the support section of our site, this will start to make more sense
You can write to us with sample projects at techsupport@revisionfx.com so we can help you set up your morph.
Pierre
NOW: The motion morph also has a "from" and a "to" shape
Jaime Escalante
on Jul 22, 2008 at 11:35:58 pm
I have one talking person with a fixed camera that I would like to morph to a second morphing person on another set with a fixed camera.
I tried following these steps -- I got the Warp down, but the Morph is not working. Does anyone have a nice YouTube video or something that walks you through a quick-and-dirty morph?
We are doing 20 morphs in 10 seconds so they definitely don't have to be perfect.
Thanks for any replies or information.
--Jaime
Pierre Jasmin
on Jul 22, 2008 at 11:57:10 pm
Which application (AE, Shake, Fusion, Combustion,...?)
Pierre
Jaime Escalante
on Jul 23, 2008 at 4:22:16 am
After Effects.
I considered using Liquify because when you're doing one morph every 20 frames you don't need "perfect" quality.
Thanks for the response
Pierre Jasmin
on Jul 23, 2008 at 5:21:19 am
Here some ideas on how to prepare the material for multiple morphed transitions - although for Motion Morph you could also do them one by one: from clip 1 to clip 2
There is a manual that explains what the controls do and some sample projects in the support section of RE:Flex on our website.
1) Motion Morph or Morph?
With Morph you can make a morph between two frames of a same sequence, with Motion Morph between two clips
A. MORPH tool: With Morph you can create motion between the last frame of a sequence and the first frame of another sequence and to do so you would in a precomp stack all your clip and offset them so they line up in time, and if you want say 5 frames transition between each, leave 5 empty frames between each clip in your precomp, which we call here the black frames.
B. Take that comp and put it into a new comp in which you apply RE:Flex Morph. Animate the button "Picture Key" so it's checked at the last valid frame, then unchecked at the first black frame, then checked again at the next sequence first frame.
You should now have a sequence without black frames which blends frames where there was black.
Then you can place some masks on the last valid frame of a sequence, set the Mask path to animate, then on first valid frame of next sequence (after the last black frame) move the shape vertices so it represents about the same location then the other images (eg a shape for eyebrows - then move it so it's on the next frame -- on the eyebrow).
2) Motion Morph: If you want to cross-morph sequences with action, You have to organize your 10 sequences in two different precomp I think and hopefully you have some head and tail on these clips. Let's imagine you have ten clips you want to cross-morph or chain-morph. In one precomp you stack clip 1,3,5,7,9 and in the other you stack in time order 2,4,6,8,10. Another thing, let's say they are are 5 clips of 5 seconds edited, for the second comp start the first clip (offset start point) so it starts at 2.5 seconds.
B. OK you have two sequences and you drop these two sequences into a new comp. You apply Motion Morph to the first sequence and you select as "Warp To Layer" the other clip. First see the value Global Blend. Animate it to mask the hard cuts in each of the two sources. So if we used 5 seconds shots, then every 2.5 seconds that value will alternate between 0% and 100% (it will be 0%/100% where you in the precomp switched from a clip to another).
Now play RAM preview, it should just be a chained dissolve if you are in Warped and Blended mode.
C. Go to the first frame, copy the key-frames of Global Blend and Paste it into "Global Warp". Set Display to Warp From mode.
* Make a small line on a feature in first frame.
* Duplicate (ALT D on windows)
* Press somewhere on the effects control window (how I found to terminate shape draw in AE)
The Duplicate is to create a corresponding "To Shape"
* Change to Display Mode Warp To
* Check Auto Show Hide Splines
* Place the spline to corresponding features
(Twirl open masks and make sure the path are in animate mode)
** Do a few shapes like that - animate to start every 2.5 seconds and then add more inbetween positions for shapes as needed
** sometimes the AutoAlign will do a good job on fast transitions
Pierre
Jaime Escalante
on Jul 23, 2008 at 6:43:05 am
Thank you for your information -- I will give it a shot
--Jaime
sean barrett
on Apr 30, 2010 at 10:57:07 pm
I'm finding this plug in very frustrating moreso because I have seen how powerful and wonderful it can be. The "Manual" included is a bit vauge describing concepts over real world tutorials which are much easier to learn from. It's 2010 the year of video and video tutorials, couldn't someone from RE:FLEX quickly do a a quick video tutorial morphing from one person from another. I know it will only lead to more people buying this awesome plug in. I consider myself very savy with AE yet I am struggling to no end to get this expensive plug in to work. I have scoured the internet in search of a solution and everyone seems to be saying the same thing, "where is the tutorial?"
Pierre Jasmin
on May 1, 2010 at 6:04:53 pm
New video tutorials for RE:Flex should happen sometimes this summer.
Seen this example that Wes from Automatic Duck did:
http://wes.plate.net/2009/12/goodbye-jump-cut/
Pierre
PAUL BOYD
on Jul 27, 2010 at 5:11:25 pm
Hello,
I'm using your plug-in to morph together the stills from a camera array (like in The Matrix). I'm assuming the morph tool is the way to go (let me know if it's not).
I'm wondering what the purpose of the second precomp is?
Can the warp not be done in the initial Comp?
Thanks for your time.
Paul SG Boyd
PAUL BOYD
on Jul 27, 2010 at 5:12:40 pm
Oh yeah,
I'm on AE CS5 and although I've done this technique before, I did it with different programs. I'm VERY new to AE, so the more simple the explanation, the better!
Paul SG Boyd
Pierre Jasmin
on Jul 27, 2010 at 6:02:06 pm
The precomp in the examples in the sample projects is used to locate in time the stills so if when you animate the button to use Pix key-frame in RE:Flex Morph it is at the proper place in time. (eg still 1 at frame 1 and still 2 at frame 30 and still 3 at frame 35).
If the stills come from a sequential still capture rig you might also consider to perform this work with Twixtor using "Frame Number" parameter animation instead. Twixtor PRO and RE:Flex Morph with Auto-Align are similar except for how the material has to be prepared for the tool. For example it's much more practical with RE:Flex to remove bad frames or animate photos (e.g. make them talk) from a small set of stills.
Pierre
PAUL BOYD
on Jul 28, 2010 at 3:45:46 pm
Hi again Pierre,
So I followed the picture to picture Flex Morph instructions, and it's a good start to my project, but there are some areas where I think I'll have to draw shapes.
Is there a way to combine the techniques of auto align and masking?
Thanks again! I'm already seeing this plugins potential!
Pierre Jasmin
on Jul 28, 2010 at 4:15:19 pm
Yes you often need to use both together.
What I personaly do usually is draw a few shapes, animate them at key-pix location to the corresponding location and then turn auto-align and see what happens. If there is some place that still has gnosting, this tells me where I should put the next shape(s).
Pierre
PAUL BOYD
on Jul 28, 2010 at 7:07:48 pm
You just draw them on the comp that already has the morph or in the precomp? Then animate between kayframes?
Sorry, I'm still figuring out AE, let alone the plug-in.
Thanks again!
Pierre Jasmin
on Jul 29, 2010 at 1:01:21 am
On the layer that has the morph effect applied
PAUL BOYD
on Aug 13, 2010 at 5:34:35 pm
Hi again Pierre,
As we get deeper into the morping process, we're running into some problems: as objects pass in front of one-another there is all kinds of distortion that happens. ie. a hand passes in front of a face during the morph and everything goes all mushy.
We've discovered that doing a separate comp for every problem shape will do the trick, but it's super time consuming and we'll have a big compositing job to do at the end of the morphing.
Can you think of another way to clean these problem spots up?
Paul SG Boyd
Pierre Jasmin
on Aug 13, 2010 at 7:11:57 pm
Yes some work involved...
Sometimes you can use the boundary shape but there is only one
In case if you have to do multi-pass morph, and you move a front layer in a way that leaves small holes, you can use RE:Fill Area to cover up the background hole.
Pierre
PAUL BOYD
on Nov 14, 2010 at 7:20:11 pm
Hi Pierre,
Here's the finished spot that i directed and did the post on for a spec competition.
Your plugin came through.
Enjoy!
Paul SG Boyd
Pierre Jasmin
on Nov 14, 2010 at 7:39:56 pm
Excellent!
Looks pretty good
Pierre
Matthew Hansel
on Aug 9, 2010 at 6:45:41 pm
Hi (Anyone)~ !
I'm Matt Hansel, an art director working (currently) for a music company in Nashville, TN. - We're developing a website
currently, and have paid for "Adobe After FX" liscenses w/Adobe...
I went online looking for good "morphing" software - when I read about RE:flex, I thought I would try out the demo version (PC software) for windows... installed it... and - no dice. The "RE:flex" plugin did
not show up ANYWHERE when I launched Adobe After FX (CS4).
I don't usually have this kind of trouble w/after FX plugins... are there some kind of special instructions somewhere for idiots like me who can't seem to get the demo up and running...?
Thanks for your (anyone's) help in advance,
~Matt Hansel
Grand Vista Music
(Project) Art Director
mhansel@grandvistamusic.com
PS. Once I've evaluated the demo VS. - & demostrated it to management - I can use my pull here to persuade GV that we need to buy the licensed version to use the plug-in...
Pierre Jasmin
on Aug 9, 2010 at 7:22:59 pm
When you run the installer did you select [x] After Effects CS4?
It should show up in the RE:Vision Effects folder in the Effects menu.
It should place the plugins automatically here:
C:\Program Files (x86)\Adobe\Common\Plug-ins\CS4\MediaCore
Pierre
Matthew Hansel
on Aug 9, 2010 at 7:26:48 pm
Thanks - Pierre!
Much appreciated! I'll try to locate it
in the plug-ins folder before I post next
time to see if it even installed...
I''ll repost soon w/my discovery either way...
Thanks again,
~Matt H>
