recreate every second frame using Twixtor
COW Forums : RE:Vision Effects
cow
freefalling
on Jul 11, 2007 at 10:14:59 am
There's a trick for improving compressed video (DV,HDV, DVCPRO etc.) to get a better key using Motion Estimation (there's even a product from The Foundry).
My question is.
I want to keep the speed at 100%, but recreate every second frame using Twixtor, based on the previous & next frame.
How can I set it up ?
Eran
shin kurokawa
Re: recreate every second frame using Twixtor
on Jul 11, 2007 at 2:27:38 pm
You mean, like stretching it then shrinking it,
all in one pass?
Or, prep/precompose a sequence that contains
half as many frames (i.e. throwing out every other frame)
then use that (i.e. half the fps of the original) to
create a new sequence that contains twice as
many frames (i.e. same fps as the original)?
Just curious though:
how would throwing out every other frame
improve compressed video?
Having said that, I do this kind of thing
for cartoon restorations (from film) but
not for live footage. So I'm just curious...
-Shin
cow
freefalling
on Jul 11, 2007 at 4:03:52 pm
Shin,
I can't really tell you why it's working, but I saw a demonstration of it with good results.
Thanks for tip. Quite basic when you think of it :-)
Eran
