Final Cut Express
COW Forums : RE:Vision Effects
Maurizio Panella
Final Cut Express
on Jul 2, 2007 at 11:29:12 am
Hi all, I'd like to use Twixtor with a MacBook C2D - 2,16GHz and Final Cut Express: do you think is possible?
Thanks in advance, Maurizio from Italy.
Pierre Jasmin
Re: Final Cut Express
on Jul 2, 2007 at 10:26:35 pm
Not right now, it's not really an option for the type of things we do.
I know Premiere Elements on windows (that's what $99?) is supposed to support our plugins... not sure they will release a Mac version once the CS3 rollout is over.
For now, the applications listed at the link below are the only one we officially support:
http://revisionfx.com/products/twixtor/compatibility/
Pierre
RE:Vision Effects
Dave Iron
on Jun 30, 2008 at 7:58:11 am
mo va a cagher.com Espress on FinalCut
Dave Iron (AL)
Pierre Jasmin
on Jun 30, 2008 at 9:16:02 pm
If I understand your question properly :)
For your information,
FCE might share the same source code as FCP but lags some dot versions before what makes it in FCP comes to FCE
So at some point Twixtor FxPlug will start to work in FCE (the changes Apple did so it works will be part of the build) - At that point we will add FCE as supported application.
Pierre
Pierre Jasmin
on Apr 12, 2009 at 4:02:17 am
OK, it's now possible to run Twixtor in FCE (4.0.1 and over)
