arrow keys to nudge points?
COW Forums : RE:Vision Effects
Matthew Beall
on May 27, 2007 at 2:14:13 pm
I'm using the Flex Warp operator in combustion.
Can you not move/animate the points using the arrow keys? I'm doing some extremely fine warping. The mouse's movements are too extreme.
Plus, I find arrows easier to quickly set keys to all points by selecting them all and doing a quick up/down arrow.
Pierre Jasmin
Re: arrow keys to nudge points?
on May 28, 2007 at 1:45:27 am
Please file a bug to Autodesk
Bug being as you describe that selecting a mask point in RE:Flex and pressing the up and down arrow does not move the point. This works in other Combustion tools like Draw Mask and would be expected to work in RE:Flex as well (same polygon toolkit).
* Moving the tracker position within RE:FLex works but that's of no help.
* If you select the point in the timeline, there is a way (pressing shift) to increase the increments but apparently no way to decrease it so it so it moves by sub pixel increments.
The only I can think to work around this today is by working on a zoomed up image (pressing the "+" zoom-in button a couple of time)
© 2018 All Rights Reserved
