ReelSmart Morion Blur creates corrupted images
COW Forums : RE:Vision Effects
pictured
on Nov 21, 2006 at 4:07:50 am
ReelSmart Morion Blur v 3.2.4 on Adobe After Effects 7 is creating random corrupted images. The corruption looks like thin horizontal gaps across the image where the image hasn't been rendered or has been shifted horizontally out of place. The plugin also crashes after effects too.
Any help / advise is greatly appreciated as this would be a decent plugin if it actualyl worked.
thanks
Brendan
Pierre Jasmin
Re: ReelSmart Morion Blur creates corrupted images
on Nov 22, 2006 at 2:53:54 am
Brendan
Check first that the frames you are MotionBlurring are not themselves corrupted to start - you might need to Purge All Memory or something to see that otherwise AE might just return to you whatever is currently in that buffer
Pierre
