NTSC to PAL in Twixtor
COW Forums : RE:Vision Effects
suzy_22
on Nov 3, 2006 at 3:49:09 am
Hi, I am new to Twixtor and I am trying to convert NTSC foot to Pal in FCP HD. I am having a hard time trying to wrap my head around the "sequence" settings and the filter setting to the clip. Does anyone know of the some good "appropiate" settings in the twixtor filter to use to make a clip go from NTSC to PAL? Or any website that might help with this?
thanks in advance for any help!
shin kurokawa
Re: NTSC to PAL in Twixtor
on Nov 3, 2006 at 3:57:37 pm
Have you checked out the online projects at :
http://revisionfx.com/rstwixtortutorials.htm
Also the FCP section of that big (200+MB)
"Twixtor Basics" html tutorial.
It covers this plus many topics.
-Shin
alan smithee
on Nov 3, 2006 at 4:02:05 pm
if you look in the 2005 archive on this forum there is a thread covering ntsc to pal. maybe this will help. this is the link.
http://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=69&archive...
Peter Litwinowicz
on Nov 3, 2006 at 7:53:24 pm
In addition to the tutorials that Shin pointed out, I have additional info for you.
If you have After Effects, I highly recommend that you do it there. In After Effects NTSC to PAL conversion using Twixtor is very easy, the process is explained here: http://www.revisionfx.com/generalfaqsNTSCtoPAL.htm . If you do not have FieldsKit (another product of ours) then you can skip step 3.
From the Features subsection on our website:
  • Frame rate conversions made easy (Important Note: frame rate conversions are supported only from within After Effects and Combustion ).
While we don
