Twixtor demo questions using 30p footy
COW Forums : RE:Vision Effects
wArden
on Nov 23, 2005 at 4:53:47 pm
Set up: Final Cut Pro HD, Canon GL2 shooting in
Peter Litwinowicz
Re: Twixtor demo questions using 30p footy
on Nov 23, 2005 at 5:47:04 pm
[wArden] "Question: I
wArden
on Nov 23, 2005 at 6:07:55 pm
Peter,
Thanks for the quick response.
I found the manual. I guess I was just over-looking it.
What you said about not needing the DeInterlacer was what I had expected. I just wanted confirmation.
I will give creating a separate matte for the foreground a shot. There are only a couple of points that are causing me trouble and may be confusing the plug-in.
Is there a way that I could send you a compressed version of the clip so you can see what I am talking about?
Peter Litwinowicz
on Nov 23, 2005 at 10:43:27 pm
sure you can send along a clip. If it's less than 5Mb, send it to techsupport@revisionfx.com.
Otherwise, perhaps you can make it available via an ftp or website?
pete
Pierre Jasmin
on Nov 23, 2005 at 11:42:26 pm
You might consider as well checking TwixtorBasics Tutorials
which you can get from here:
http://www.revisionfx.com/rstwixtortutorials.htm
Pierre
wArden
on Nov 24, 2005 at 1:36:46 am
Peter, I trimmed the clip down to just under 2 seconds in length and compressed it to 360x240 so the file size is very small. I'll send it to you to get your opinion on it.
Pierre, I have already went through the tutorial but I never checked out the manual. I'm doing that now. ;)
