Final stage of NTSC to PAL conversion using RE:Vision FX
COW Forums : RE:Vision Effects
jennifer
on Jul 4, 2005 at 6:31:03 am
I was recommended to post my question here instead of After Effects forum as I might get a better answer...
I
Pete Litwinowicz
Re: Final stage of NTSC to PAL conversion using RE:Vision FX
on Jul 4, 2005 at 4:34:18 pm
[jennifer] "ne thing I don
jennifer
on Jul 4, 2005 at 5:32:00 pm
Thanks a lot Pete,
I made a PAL DVD and the lines disappeared. Actually, I'm really impressed how well it looks ! One thing happened is in the scenes with a lot of motion and camera shake there is a sort of motion "trail"(not too visable, but it's there). Is that because I set "blend" as a interpotation method in Twixtor ? Shall I set it "nearest" or is there other way of getting rid of it ? Thanks,
Jennifer
Pierre Jasmin
on Jul 5, 2005 at 12:15:42 am
Is Motion Blur Compensation set to 0?
Going from NTSC to PAL is a form of speed-up so if MB is not set to 0 it will add some motion blur to simulate the difference in shutter opening if you like. If you don't want that make sure it's set to 0
Also, yes, particularly when you speed up, you might prefer nearest to blend mode look (your call). Also it will be faster to render if that is an issue for you
Pierre
http://www.revisionfx.com
jennifer
on Jul 5, 2005 at 8:08:58 am
Thanks very much Pierre and Pete,
I changed the setting and worked like a charm ! I'm really happy with the final quality now!
Cheers,
Jennifer
