Woobles with Motion Morph
COW Forums : RE:Vision Effects
Ian Tucker
on Jun 1, 2005 at 2:25:59 pm
Hi all,
I'm doing what should be a fairly simple motion morph of a peach, morphing from immature to ripe (I'm using motion morph because there is a camera zoom on both shots). The morph looks great except for a few little, well.. woobles is the only way I can describe it. Does any have an idea of what might be causing the images to wooble as they morph. My masks aren't very complicated so I can't seem to figure out where the problem lies. Any help would be appreciated.
I'm using the latest Reflex (2.3.7 I think), After Effects 6.0 on a Dual 1.25 G4, Mac OS 10.3.8
Ian
Pierre Jasmin
Re: Woobles with Motion Morph
on Jun 1, 2005 at 2:56:42 pm
Do you have "Hold Edges" on? That could cause this.
Pierre
wwww.revisionfx.com
shin kurokawa
on Jun 1, 2005 at 3:21:02 pm
This might help too:
if you crank up antialiasing and
check to see Warp/Color Percentages are
animated smoothly. You can do this
either by using the Global Percentage
controls (if they're checked), or
on a per-mask basis (more complicated
in AE but more flexible... no puns
intended!).
-Shin
Ian Tucker
on Jun 1, 2005 at 3:37:15 pm
Thank you both. Both suggestions seem to be making it look better already. I'll let you know how it turns out.
