Twixtor Frame Rate Converion?
COW Forums : RE:Vision Effects
Dustin Cross
on May 23, 2005 at 8:34:12 am
Aloha,
I downloaded the demo of Twixtor because I wanted to test the Frame Rate Conversion, but there isn't any Frame Rate Conversion in the current demo for AE 6.5 Pro. Reading stuff about Twistor it shows an input frame rate and an output frame rate on older versions, but that isn't on the demo I just downloaded. How do I do frame rate conversion from 30p to 25p with Twixtor in AE 6.5 Pro?
Mahalo,
Dusty
Dual 2.5Ghz G5 w/ 2.5GB ram, Decklink HD, Decklink Multibridge, MOTU 896HD
JVC DV5000, 2 Sony HDR-FX1, JVC BR-DV3000U, JVC 19" HD monitor
shin kurokawa
Re: Twixtor Frame Rate Converion?
on May 23, 2005 at 7:56:40 pm
The info you want are at:
http://revisionfx.com/generalfaqsNTSCtoPAL.htm
http://revisionfx.com/rstwixtortutorials.htm
the Twixtor Basics tutorials,
Under After Effects -> Frame Rates
Good luck!
-Shin
Dustin Cross
on May 23, 2005 at 8:20:26 pm
Shin,
Thanks for the reply, but the tutorial says set the "output frame rate". There is no "output frame rate" option in the AEplugin demo. In output options I can change speed % or total number of frames, no "frame rate". I am downloading the 217MB tutorials right now to see if there is anything different.
Mahalo,
Dusty
Dustin Cross
on May 23, 2005 at 8:43:30 pm
Shin,
I just went through the 217MB tutorial and it talks about changing frame rates and what frame rates are, but never mentions how to do it.
Mahalo,
Dusty
Peter Litwinowicz
on May 23, 2005 at 8:49:44 pm
Sorry.. our FAQs are out of date.
In order to change frame rates within AE, you simply tell Twixtor the input frame rate. Twixtor 4/4.5 gets the output frame rate from the composition settings.
You don't need to set the output frame rate anywhere... it's automagic. For example, if you want to convert 15fps to 29.97, you drop your 15fps footage into a 29.97 composition. Apply Twixtor and set the input frame rate to 15. The output frame rate will be retrieved from the composition.
Pete
Peter Litwinowicz
on May 23, 2005 at 8:52:09 pm
I just found a reference to Output:Frame rate from our NTSC to PAL conversion FAQ. Anywhere else I should look?
Pete
shin kurokawa
on May 23, 2005 at 9:09:02 pm
Oops, Just noticed there's an "output frame rate"
paragraph in the page :
Twixtor 4.5 Controls in After Effects
(....333FSAE/FSAE_01.htm)
<--- Dustin, ignore that paragraph. Output
FR + field controls in Twixtor (AE) were
removed in v.4.x. Only combustion version
has the out FR control still.
Arrgh! Not enough caffeine!
-Shin
Dustin Cross
on May 23, 2005 at 9:14:21 pm
Pete,
That was the only place I saw it referenced on the Re:Vision FX website. I found reference to output framerate on other websites talking about older version of Twixtor.
Mahalo,
Dusty
