3ds Max / Brazil > AE or Combustion : Can I use RSMB Motion Vectors ?
COW Forums : RE:Vision Effects
VIEW ALL   •   PRINT   •   NEXT >>
Daniel R
on Apr 2, 2005 at 12:06:37 am
Hi ,
I've been on the RevisionFx website reading about using RSMB in AE . The thought of using 3D package vectors is really exciting ...
It seems like Max 6 / Mental Ray can export vectors in RPF files ... but that's it for AE .
Is there any other workarounds for Brazil Renderer ?
Are there more renderers supported when exporting RPF > importing into Combustion ?
Regards
Daniel
Pierre Jasmin
Re: 3ds Max / Brazil > AE or Combustion : Can I use RSMB Motion Vectors ?
on Apr 2, 2005 at 8:17:38 pm
In theory the Pixel Velocities from the Max scan-line renderer should work. In practice it's something no app currently interprets correctly on input except perhaps Digital Fusion at least for getting it in (although the Y seems transposed and you need a pixel scripting custom tool to remap it). The Motion out Max via Mental Ray is broken in Max7,7.5 , we filed a bug report... So what to do?
Things to try:
A.
http://www.scriptspot.com/
search: RPF channel
The President of Boboland seems to have such a script (not sure it it works)
If you can extract images out of it, I will certainly look at it.
B.
Why don't you ask the people that do Brazil? If they do the renderer, they can actually do multi-pass for cheaper. Else if you know someone that can write a Brazil shader, I can give instructions.
Pierre
