how to get this kind of effects in particular plugin
COW Forums : Trapcode
Chandra Mouli
on Feb 2, 2018 at 9:43:07 am
please check the video mentioned in the below link.
https://s3.envato.com/h264-video-previews/22ef2bec-b89c-4171-acf1-b7c35cc4c...
I'm trying to get that effects from Particular plugins, but couldn't get the better result. can any body please help me with settings/adjustments in the Particular plugin.
Thank you
Steve Bentley
Re: how to get this kind of effects in particular plugin
on Mar 21, 2018 at 6:54:57 am
Thats pretty straightforward. Make the emitter a light (hint: you have to name the light correctly) and have the light follow a spline or a write on effect or just keyframe it. It will spit out the particles. Then set the gravity to something other that zero.
The key to the sparkle effect is to change the color and opacity over time with really spiky "over time" graphs. And use either screen or add as your blend setting. This will make the particles appear and disappear like they would when they sparkle and then they do show up they will add up to white to create those hilights in the sparkles.
