Trapcode MIR 2.1.2 stutter in scroll
COW Forums : Trapcode
Glen Jennings
on Jan 3, 2018 at 1:55:28 am
Using After Effects 15.0.0
When key framing a scroll on either Y or X axis Trapcode MIR stutters and does not give me the smooth motion. I have a texture layer that is a JPG, not sure if that is part of the issue.
Is anyone in depth enough with this plugin to know which parameter I can tweak to stop the irritating stutter in my animation?
If you can't tell a tale tall then it's not a tale at all.
Kalleheikki Kannisto
Re: Trapcode MIR 2.1.2 stutter in scroll
on Jan 6, 2018 at 12:40:17 pm
Perhaps the most usual reason for stutter is too fast a motion without motion blur. So that would be the first thing to look at -- either decreasing speed or adding motion blur.
Senior Graphic Designer
