3D Stroke - Thickest point of stroke follow trim
COW Forums : Trapcode
Baard Kolstad
on Sep 1, 2016 at 1:46:14 pm
I was wondering if it is possible to have the thickest point of a 3D stroke follow along as a path animates in.
So without "Stroke sequentially" checked this is the current result:
This is the desired result:
So it would basically be that a circle follows the trim with a tail behind it. I'm open to alternative solutions.
Baard Kolstad
Re: 3D Stroke - Thickest point of stroke follow trim
on Sep 1, 2016 at 2:39:28 pm
I just realised that the solution is just to reverse the start and end thickness ratio. But if someone is looking for a way to do this and still keep the thickness ratio, make a duplicate, reverse the ratio, keyframe the stroke width from whatever the thickest width is to 0.
