Trapcode 3D Stroke - Move point in z-space
COW Forums : Trapcode
Baard Kolstad
on Aug 16, 2016 at 2:55:09 pm
I'm trying to use Trapcode 3D Stroke to move a certain point further back in z-space, but the controls remain flat. I have made an example to demonstrate my problem.
So this is the how I want it to look when seen from front, the point that is marked with a green circle is the point I want to move back in z-space:
This is how the shape currently looks when it is rotated in y-axis. So the point marked with a green circle is the same point, the yellow is an example of where I want it to placed (Without effecting the look of the shape when seen from front). :
Thanks in advance for all help!
Kalle Kannisto
Re: Trapcode 3D Stroke - Move point in z-space
on Aug 16, 2016 at 3:24:45 pm
You'll need to construct it from two 3D stroke effects with their own paths and with the second one rotated 90 degrees, transfer mode set to normal:
10423_3dstrokeconstruct.aep.zip
Kalleheikki Kannisto
Senior Graphic Designer
