How to create this effect.
COW Forums : Trapcode
Justin Mettam
on Aug 11, 2016 at 4:38:45 am
I need to recreate this effect (see image)
Should I use trapcode Particular, Form or something else?
Does anyone know of a template that can get me close?
I have seen templates and tutorials that help me build a nebular kind of look, but this more big sweeping wispy orbits rather than turbulence.
Thanks in advance.
Justin Mettam
PreViz & 3D-Generalist
mettam@hotmail.com
415 261-7633
http://www.JustinMettam.com
Kalle Kannisto
Re: How to create this effect.
on Aug 11, 2016 at 1:07:46 pm
That looks like a flame fractal, so maybe this:
http://aescripts.com/ae-flame/
Here are someone's experiments with the plugin:
http://aescripts.com/learn/fractals---experiments-with-ae-flame/
Kalleheikki Kannisto
Senior Graphic Designer
Justin Mettam
on Aug 11, 2016 at 6:02:51 pm
Can the AE_Flame plugin let me orbit around the effect. Or at least let me rotate the effect in 3D?
The reason I ask is because I have to embed graphics at varying depths with in the fractal.
So far I haven't been able to achieve this.
Kalle Kannisto
on Aug 12, 2016 at 12:23:59 pm
Probably not. I don't have the plug-in, but I doubt it is a 3-dimensional fractal. What you could do, however, is render some still images of the fractal and put them on different 3D layers, with some of them rotated around a common center point in various directions, composited in screen or add mode to create the apparency of 3D space. And you could use expressions to make the layer opacity fade when they get too close to being edge-on to the camera.
Justin Mettam
on Aug 12, 2016 at 5:50:59 pm
Thank you so much Kalleheikki. Your advice helped me a lot.
Justin Mettam
mettam@hotmail.com
415 261-7633
