Trapcode MIR - Taper to get a tornado?
COW Forums : Trapcode
Gustav Affe
on Jul 16, 2016 at 1:13:45 pm
Hey,
i have just tested around with Trapcode MIR a few hours yesterday with the plan to form a tornado
which looks like in this video:
(0:35).
Of course it does'nt have to be exactly the same but i can't find a parameter to taper the form in one axis.
The diameter has to decrease in some way.
Does anyone have an idea of how to do this?
I'd be very thankful to know what i can do.
Thank you.
Kalle Kannisto
Re: Trapcode MIR - Taper to get a tornado?
on Jul 16, 2016 at 7:57:04 pm
If you bend Y in the positive direction until you get a cylinder and then bend X in the negative direction, you get a shape that is bent in at the center. You can use the top part of that for the tornado. You can use a texture that is transparent at the bottom to get rid of the bottom half if need be.
