Trapcode Shine and shape layers?
COW Forums : Trapcode
Lou Ruiz
on Dec 26, 2015 at 12:36:57 am
Hello,
I recently purchased trapcode suite 13 and have been having a blast playing around with it. Now that I want to apply it to something I am working on, it won't work. I guess what I should be asking is, will Trapcode work with shape layers?
I redrew a shape in illustrator and have imported it into after effects, I applied Trapcode Shine but nothing happens. Not sure why when it easily applies to text layers. I have also tried converting the AI file to a shape layer in after effects with no success.
I am however able to apply the effect if I make the shape white and and add a black background in illustrator, and import as footage, but then I have to deal with the opaque background.
Is there a way to add Shine to the shape layer, in the same way it works with the text?
Thanks in advance.
Lou Ruiz
Re: Trapcode Shine and shape layers?
on Dec 26, 2015 at 1:15:41 am
Grrr, just figured it out. Black shapes/text don't work, seems to work with anything other than black. But I can work around that.
Scott Benson
on Feb 22, 2017 at 10:00:08 pm
It does work with black, you just have to go into the Colorize option in Shine and instead of basing it on Lightness (default), you base it on Alpha.
