Particular - Emitting away from center in two dimensions
COW Forums : Trapcode
Tori DeYeso
on Sep 10, 2015 at 12:44:57 pm
Hi all, I'm trying to set up an emitter that will produce something that looks like this:
http://cache1.asset-cache.net/xc/523163341.jpg?v=2&c=IWSAsset&k=2&d=EwWBXZS...
Where the particles are being emitted away from center in X and Y. I'm currently using a custom emitter layer (the outline of a sphere) but having trouble getting the particles to not cross the center. Tried playing around with spherical field and wind but still couldn't achieve the look I wanted. Any tips would be greatly appreciated!
Kalle Kannisto
Re: Particular - Emitting away from center in two dimensions
on Sep 13, 2015 at 4:52:33 pm
You could make the emitter rotate rapidly around the center point at a distance and always emit in the same direction (away from the center).
Mike Park
on Sep 13, 2015 at 11:31:01 pm
Just emit from a point and key frame the particles opacity. That would be the easiest way.
