Trapcode and camera 3D dolly move
COW Forums : Trapcode
Rafael Macho
on Aug 21, 2015 at 7:18:26 pm
I have followed this videocopilot tutorial
I have 3 pre-comps with 3 Particular plug-ins (using Sprite as element set to multiple clips set at 400x400 pixels playing in loop) with their camera rigged to my main composition (a Z-axis dolly move with over ~10x zoom out)
When I add another pre-comps with either PSD or AI elements, for some unknown reason, the camera (50mm setting) is not matching.
Wondering if someone would have some insight about such a unique situation.
Thanks in advance.
Design + Creative + Animation + Illustration
Kalle Kannisto
Re: Trapcode and camera 3D dolly move
on Aug 22, 2015 at 7:07:45 am
Are these new precomps done in the same way, i.e. by using the Pre-compose script? The script links the camera settings of the precomp to the main comp camera, so if you make new precomps without the script, they will likely not match.
If this is the case, the solution is to use same (script) method for creating the new precomps.
© 2018 All Rights Reserved
