Sound Keys No Outputs (always 0)
COW Forums : Trapcode
NdM Hd
on Jul 20, 2015 at 10:39:25 am
I'm currently trying to make an audio spectrum. When I select the audio layer and then press apply to generate keyframes from it, the output for all ranges is always 0 (I only need range 1).
I have been searching for a solution for hours but none seem to work. This happens every time I use sound keys on any audio layer.
Things I have tried:
  • Using uncompressed audio. (e.g. WAV)
  • Holding the apply button for a few seconds.
  • Setting screen resolution to full.
  • Moving the sound keys layer and repeating the process.
  • Using pt_OpenSesame to import the file (it did import to CS5.5 but no effects were carried over because it's a trial, paid costs $70...
  • But all of these come to no avail.
    There is one solution I have heard of but cannot do myself.
    That is opening the file in CS5.5 and having that use soundkeys.
    I do have CS5.5 but the file was made in CC2015.
    That means to get the file to work I have to have:
    CC 2015
    CC 2012
    And only 2 of which I have.
    Is there any alternative or anyone who could complete the 'downgrade' process?
    © 2018 All Rights Reserved
