Form - using color alpha map with audio react?
COW Forums : Trapcode
Marcelo Comerlato
on Jun 5, 2015 at 1:37:11 am
I'm trying to use Form to create audio react distortion a with a video. I set form's size and particles to 1920x1080, then set the color alpha map to the video later to create a duplicate layer of particles. But after setting audio react to a music file, and setting up two reactors for disperse and fractal, nothing happens. The particles won't react tot the music. Any ideas why?
Kalle Kannisto
Re: Form - using color alpha map with audio react?
on Aug 16, 2015 at 8:42:22 pm
You have to set the amount of dispersal and fractal as well. Audio react works as a multiplier or "throttle" for those effects. If they are set to zero, nothing happens.
