Stepping in particle stream
COW Forums : Trapcode
craig hellen
on Jun 1, 2015 at 2:09:29 pm
Hi Guys.
So after reading up on this
(fab way of orienting static particles to the path you are placing them on)
I want to make a "ribbon" using a textured polygon.
I seem to have been able to get the expression working (as in the particles seem to be following the path and orientating them correctly), however I have a problem.
For some reason the stream seems to be stepped, this does not change if I change the partical count, the particles get more dense but the steps remain.
Please see the example screen shot.
Im sure its something simple but its brick wall banging here!
Please help, yours in after effects
Co-Director Podchains Ltd
Video Producer / Motion graphics designer
© 2018 All Rights Reserved
