FORM: Obj's Orientation and AnchorPoint
COW Forums : Trapcode
Michael Powers
on Oct 14, 2014 at 6:40:40 pm
What are the rules governing an Obj's orientation and anchorPoint in FORM?
I am exporting from 3dsMax using the Obj: CD4 settings. The geometry is centered - yet it comes in with anchor point not centered.
I found nothing about this in the help. Any suggestions?
Michael Powers
Creative Director / Animation
3DBOXX W8920Processor
Dual Xeon CPU E5-2670 0 @ 2.60GHz, 2601 Mhz, 8 Core(s), 16 Logical Processor(s)
Windows 7 Professional - 6.1.7601 Service Pack 1 Build 7601
32.0 GB
NVIDIA Quadro K5000 /
Driver Version 7.1.542.0
Ohad Dadon
Re: FORM: Obj's Orientation and AnchorPoint
on Feb 7, 2015 at 1:56:05 am
Im here with the same problem. i thought about doing the animation of the object inside form, but the anchor point is alwayes centered, and there is no way that i could find to change it. ( i want the object to rotate from the buttom)
So i set the animation inside Cinema4d and then imported an obj sequence into form, but then I couldnt match the object to the the footage. this "ObJ Sequence" method is one way to get around this that may help you.
For me, Im still looking for a way to bypass that anchor point if anyone has a solution.
© 2018 All Rights Reserved
