Trapcode Form with OBJ (static) - Particles have a frame-by-frame vertical jitter
COW Forums : Trapcode
Declan Zimmermann
on Apr 23, 2014 at 2:34:32 am
Any help appreciated as I am a bit under the gun here.
See the collected AE Project file, including OBJ source used for Form:
7391_formwobblefolder.zip
The camera, OBJ scale and Z-offset are animated.
All other parameters that I am aware of (layer maps, fields, disperse, etc) that could affect the particles are off.
As the camera moves through the particles they appear to have a vertical jitter or wobble - looks almost like a field issue, they bounce up and down frame by frame. I hope you can see what I mean. If you step frame through the animation around 2:00 you can see it.
I don't believe there are any settings that should cause this; I need a smooth motion here.
Any clues as to why this is happening?
Thanks in advance for any help.
Declan Zimmermann
Design & Motion
motiongraphicsnyc.com
twitter: @MographNYC
