Oscilloscope wave
COW Forums : Trapcode
joey campbell
Oscilloscope wave
on Mar 6, 2014 at 9:05:13 pm
Hi - I'm looking to create a simple oscilloscope type sine wave using either form or particular...I've checked the web inside out with no joy. I've also tried altering some of the presets that come with form with no luck either. My only option now is to use a wave warp distortion effect on a pen stroke but it looks very fake. Can anyone recommend a tutorial for achieving this effect in one of the trapcode products?
Declan Zimmermann
Re: Oscilloscope wave
on Apr 23, 2014 at 6:49:16 pm
Hey Joey,
I don't have a tutorial but I whipped up a quick project:
7397_particularsinewave.aep.zip
This is Particular with a light emitter and a second light for the "motion path."
The current sine path is expression generated on the motion path, however you could manually create your own path instead if you prefer.
The entire rig may be moved / rotated in 3D space using the "Positioner" null.
Hope that helps!
Declan Zimmermann
Design & Motion
motiongraphicsnyc.com
twitter: @MographNYC
joey campbell
on Apr 23, 2014 at 9:20:22 pm
Thanks Declan - much appreciated.
