Trapcode Particular Aux System doesn't recognize Layer Emitter's mask
COW Forums : Trapcode
Kosta gerdzhikoff
on Sep 9, 2013 at 11:43:27 am
Hi CC,
I have the following problem with Particular. I make a solid layer and then add a mask to shape it as I want. I precompose the layer and use it as a layer emitter for Particular.
Up to this moment everything works fine but when I try to use the aux system, Particular fills all my composition with particles. It obviously doesn't "understand" I cut off part of the layer with the mask.
I would appreciate any workarounds.
Thanks for reading
