Trapcode Particular Emitter Moving To Fast
COW Forums : Trapcode
Igor Korolchuk
on Jul 4, 2013 at 2:47:06 pm
I am trying to figure out how to slow down the particle emitter. Currently it fly's across the screen in about two seconds. I tried adjusting every possible option including gravity, velocity, air resistance, physics, etc. None of them slow down the actual emitter, they impact the actual particles themselves. Anyone have any ideas? Thanks.
Mike Park
Re: Trapcode Particular Emitter Moving To Fast
on Jul 5, 2013 at 4:51:49 pm
what is you emitter? a point, a layer, a light? Do you have a camera in the scene? The only thing which animates the emitter is the emitter position up at the top. Everything else only impacts the particles.
Igor Korolchuk
on Jul 7, 2013 at 2:46:04 am
It is on a black solid layer... No camera, or light. This has been driving me insane it literally just blinks across the screen in less than three seconds. Thanks for the response.
Mike Park
on Jul 7, 2013 at 2:15:11 pm
Send me the comp and I will look at it. park_mike@yahoo.com
Igor Korolchuk
on Jul 8, 2013 at 1:19:56 pm
I've managed to figure it out based on what you told me. Essentially I never animated the XYZ position with keyframes... I just left it at default... So that was the problem. Thanks for the input, thanks to your post I looked at the XYZ position and realized my noobish mistake.
Mike Park
on Jul 8, 2013 at 5:49:40 pm
No problem. It happens to all of us from time to time
