C4D OBJ Error
COW Forums : Trapcode
Glenn Tak
C4D OBJ Error
on Jun 22, 2013 at 11:55:00 pm
I am trying to export a simple C4D object to use in Form.
Running: C4D 14.042
AE CS6 (up to date)
Form 2.04
MAC OS 10.8.3
When I import one of the Trapcode supplied obj's they work perfectly.
I am exporting a very simple geometry from C4D as on .obj file. I've even tested a simple cube.
I can import into AE. Drop it in the time line and try to get FORM to read it... I get an error every time.
After Effects error:Form Obj error:can't open data file"/..../cube.obj" (1) (25::241)
Every tutorial I've seen on line shows this to be a simple process. Any thoughts?
TAK
Raoul Marks
Re: C4D OBJ Error
on Jun 28, 2013 at 1:29:53 am
Just spent hours trying to get my head around this problem! It turns out the issue for me was i had a "/" in the folder name... The slash was just in a folder that the project was housed in.. that was the problem.. when i moved the obj to a different directory all was fixed!!!! Hoe it works for you mate. It was like fin dining a needle in a haystack.
Glenn Tak
Re: C4D OBJ Error
on Jun 28, 2013 at 6:26:58 am
Sheesh... I guess that's what happens when you break OS protocol.
That was definitely the problem on my end as well. Thanks so much. It would have stymied me until I began a new project without a /.
TAK
Zahid Shaikh
Re: C4D OBJ Error
on May 14, 2016 at 7:18:51 pm
Please explain how did you guys manage to do it. I am using AE CC on Windows 10 x64, and on windows all the file paths are "\"
I tried a lot but no luck
