Can Trapcode Particular Explode Layer Emitter
COW Forums : Trapcode
Josh Comer
on Mar 26, 2013 at 6:49:42 pm
I want to have a video clip come into a frame. At a certain point, I want the video clip to explode into particles that wipe away some text I have on another part of the screen. I was trying to do this in particular and can't figure out how. I have trapcode Particular applied to a solid in After Effects. The layer emitter is set to layer, and the layer is set to my video clip. I can't get the particles to explode outside of the clip successfully. Any suggestions or is this beyond Particular alone?
Mike Park
Re: Can Trapcode Particular Explode Layer Emitter
on Apr 22, 2013 at 1:32:20 pm
I assume the video clip layer is set to 3d, right? You have the layer particular is applied to as a separate 2d layer, referencing the 3d source layer in particular. Make sure there is nothing weird going on with the layer particular is applied to as it should be the size of the comp and 2d. Then, get back to me if there are still problems and I will try to trouble shoot some more.
